501 engine bearings and seals
Excaliburs, New Yorks
Post by morini_tom »
Has anyone got a list of all the bearing & seal codes for a 501 engine? (late type 501 although I suspect they're the same parts as early ones)
I am nearing the teardown and want to buy all of the new bearings & seals before I begin so I can dismantle & reassemble in one hit.
No idea why I've never made a list of them before, I've rebuilt more morini engines than I care to remember over the years!
Thanks,
Tom
hombre
Re: 501 engine bearings and seals
Post by hombre »
If I am not mistaking they are even the same as in any 500 engine (if this helps...)
'It must be a .....'
Hi Tom, you asked this question two years back?
Search the past thread for a list, take care, Ian
These two links in the first message will help :wink:
http://lamaneta.org/foromecanico/viewto ... f87bd2bda8
The site of Agusti is quite interesting and good ilustrated, so it´s worth visiting, even without speaking spanish. It´s a pitty that Agusti only spent about 3 years with the morinis and then turned over to Ducati y Guzzi.
ciao
hombre
Post by hombre »
Ah yes, this was an old topic... :)
Good link Norbert!
