Moto Morini Excalibur 501
Posted: 12 Apr 2006 07:37
by Dutaceria
Do anyone want to share knowledge with me for this type of bike? I need some technical support and maybe some advise on location to purchase the parts. Send e-mail to me or just give me a call at 60195958844 :D
http://i5.photobucket.com/albums/y152/d ... morini.jpg
Good grief
Posted: 28 Apr 2006 14:03
by Coxey
What on earth happened to this bike?!!!!
Posted: 02 May 2006 10:16
by Dutaceria
This bike was kept in store for 7 years and was not even start the engine. The owner claims that the battery was always spoilt in a few month times.
Q.
1. Can I just place the battery and start the engine as usual? Will this spoilt the engine instantly?
2. Can anyone give me the correct way to make the engine alive back? Any spesified method?
Your help much apprieciated
Posted: 02 May 2006 19:27
by SteveMRC
Does your bike have a kickstarter?
Sounds a silly question to ask but I have only seen a couple of the factory customs and never taken too much notice of them. :oops:
After 7 years I would, at the very least, drain and replace the oil, put on a new cambelt, replace brake fluid and replace the battery and replace the petrol in the tank.
You may find that engine oil seals, brake lines and rubber parts in the brake system are all dried out and cracked, likewise the tyres.
Try to turn the engine over with the ignition off with the kickstarter or by putting it in gear and turning the back wheel to see if it has seized before trying to start with the button.
Not sure what the tropical climate in Malaysia would do to a bike in 7 years.
Steve
Posted: 04 May 2006 03:16
by Dutaceria
Hi there,
Thank you for your kind advise. I will try the method and will let you know the result.
Hazli
Posted: 11 May 2006 00:39
by hdbiker
Hi Hazli!
Try the advice of Steven.If you want the part list of Excalibur just go here:
http://www.morinispecial.it/manuali/Man ... alibur.pdf
If you want the maintenance manual just send me your email.I hope that excalibur will work soon!Great bike!
Many regards from Greece,Vangelis
Posted: 11 May 2006 01:05
by Dutaceria
Hi there,
Thanks you for the intention. If anyone willing to give a hand, here is my e-mail: duta_ceria@time.net.my
Hazli
