Reg/Rec
Excaliburs, New Yorks
Reg/Rec
Postby MickeyMoto » 16 Jul 2016 17:21
I had a bit of a mishap yesterday with the ignition switch and shorted the red wire to earth. A lot of smoke later and I have about 150 ohms between the +ve and -ve battery leads. When I remove the regulator / rectifier this disappears. Have I blown the thing?
thanks,
Re: Reg/Rec
Postby Ming » 17 Jul 2016 08:23
Sounds as if it was not too happy! I have found that a Suzuki SV / Bergman reg rec is about the same, but needs the connector changed to fit the Kokusan orientation (and it's freely available).
Re: Reg/Rec
Postby MickeyMoto » 17 Jul 2016 10:14
Thanks. I'll start looking....
Return to Factory customs
Who is online
Users browsing this forum: No registered users and 1 guest
