That's good news.Crankcase now split, all stripped out, only damage seems to be the main bearing and everything is relatively clean without too much debris
Do you think the plain bearings (big ends and timing side main) will be re-usable or do you plan to replace - if so where did you/or plan to obtain the plain bearings from.
And a general question to the forum what is the supply availability of plain big end shells and plain main bearings for 350s like.
