Hi all
Just made a rad cover for the GP out of an IKEA bin cost £5 . Does the job looks good .Although its filthy in the pics ,due to our lovely summer weather, you get the idea.Size wise if anyone want to make one its 350mmx197mm with 10mmx5mm cut from each of the corners,and be careful when removing the radiator screws ,1 the allen key bolts are plastic and rounds off, use a pair of pliers to hold and 2 ,don't lose the rubber washers on the rear of the radiator when removing the screws
http://s569.photobucket.com/albums/ss13 ... NY0001.jpg
Radiator cover
Radiator Cover
Thanks toggy for this post. The Granpasso radiator seems quite exposed to debris so I have made a cover using your instructions. Measurements / advice all really useful.
