Hi All
Can someone tell me the tread depth of a new METZELER TOURANCE EXP front tyre. I need to replace my rear ,but if the front has enough tread left to last another rear tyres wear I'll leave it so i can replace both at a later date .it currently has 3mm left .
Tread depth
Just to let you know the rear tread depth of a new Tourance EXP is 8.5mm. I had previously increased the preload to compensate for the ride height when the tyre was down to 1mm tread depth .and with a new rear tyre i really felt the difference in ride height .I guess you would when you lose 7mm of the rear tyre.
