Hello
this morning the display suddenly started flashing whan i arrived at my work
and gave the fault code rc. 2128 anybody knows what is the problem
The bike stil starts but the problem stays
can i savely ride back home this evening?
the dealer is closed today so i can't call him
greetings
Fault code rc2128
Re: Fault code rc2128
at home
started mesuring some things
battery 12.9V
with running engine 13.8 sounds good
doing a reset by disconnecting battery => no resuls
started to control all the fuses
fuse 2 colorcode brown 5A is blown ?????
replaced it and everything souds ok again
anybody knows what is operated by this fuse ?
battery 12.9V
Well the manuel states Ecu or instrumentation .i wouldn't worry about it unless they keep blowing .
