ebi,s map
Discuss the new Corsaro and Avio 1200s
ebi,s map
Postby torque » 31 May 2015 16:37
Where can i download ebis ecu map anyone help :!:
torque
Re: ebi,s map
Postby MonstroMorini » 01 Jun 2015 07:08
Sign on this forum here http://ital-web.de/forum/viewtopic.php?t=2875, introduce yourself and ask Ebi himself nicely.....
MonstroMorini
Re: ebi,s map
Postby torque » 01 Jun 2015 10:18
Thankyou already a member i will send him a pm
cheers :D
torque
Re: ebi,s map
Postby MisterMorini » 05 Jun 2015 09:50
torque wrote:Thankyou already a member i will send him a pm
cheers :D
Or via this link ... without asking: http://www.dhmoto.net/on_road_-_technical_page_10.html
EBI 05/06 and 08 are inside the downloaded rar archive (BIN files).
MisterMorini
Re: ebi,s map
Postby torque » 06 Jun 2015 05:59
Cheers mm your star :D
torque
Re: ebi,s map
Postby DaveH » 14 Jun 2015 09:30
You're most welcome ,,,, :D
Dave H
Beta RR300 :mrgreen:
DaveH
Best Map for UK?
Postby vtxbrit » 20 Aug 2015 19:18
Looked at my map on the standard ECU and it was loaded with the 2333MOL1249 map (2007.01.15) it ran well started well and never stalled, but after a ride I stink of exhaust gasses so I loaded the 23ACMOR95C (D) map (E3) reset tps and autotune
took it out for a quick ride seems to pull the same (no better no worse) fans come on earlier (about 90 degrees) idle is a little lumpier I will try it this weekend to see what starting from cold is like and C0's
It has Termy's (veloce) K&N filter link pipe (no Cat) a PCIII with a quick shifter connected to it, I have a spare new ECU which came with the bike allegedly with a race map installed, I will connect it up to find out what is actually installed on it but am wondering if one of the race maps would be better? has anyone tried the 23ACMOL49 C or D (UK) map comparing it to the E3
vtxbrit
Corsaro Veloce
Aprilia TuonoV4 APRC
4V 500 Weslake Barber grass tracker
2V 500 Jawa Hagon grasstracker
500 Jap 4B Barber grasstracker
500 Jap 5stud jawa speedway
vtxbrit
Re: ebi,s map
Postby vtxbrit » 24 Aug 2015 08:50
Wasn't over impressed by the 23AVMOR95C (D) map seemed lumpy around 2200rpm so changed it to the 23ACMOL49D (UK)
on initial test ride it seems smoother at the bottom end no noticeable difference in power had to trim Co's to -12 to get a steady idle
hopefully this map will improve the smell of exhaust gasses on my clothes
I also flashed my spare ECU with the 23ACMOLK22D race map to try some time,
vtxbrit
Corsaro Veloce
vtxbrit
Re: ebi,s map
Postby vtxbrit » 28 Aug 2015 19:36
took the Morini out for a long ride today and have to say that the 23ACMOL49D (UK) map is superb, very smooth when dribbling along at 30mph then when you hit a good road the torque from 2500rpm is stunning, prior to remapping the difference between my V4 Tuono and the Veloce was very noticeable but now the gap is definitely smaller, very pleased with the bike, and the quick shifter set at 65ms is spot on great fun..........the only cons are from cold its a little fluffy until it reaches 60deg and then it smoothes out and disappointingly I'm still getting a smelly jacket
vtxbrit
Corsaro Veloce
vtxbrit
Re: ebi,s map
Postby eMGe » 28 May 2018 16:35
Hello,
"Eau de Morini" is unfortunately inevitable :D
Today I got my '07 Corsaro back after a long time. A TPS cable was broken and also the speedo had to replaced. I would like to upload a proper mapping. My current setup is: stock exhaust with lambda + cat and GPR slipon with db killer. I have a custom header without CAT and Lambda.
Could you recommend a proper mapping for the setup mentioned above? Unfortunately the ebi's download link is no longer available, may I ask you to share yours? Thanks in advance.
eMGe
Re: ebi,s map
Postby MickeyMoto » 12 Jun 2018 21:05
Return to Corsaro and Avio 1200
Who is online
Users browsing this forum: No registered users and 3 guests
