still got starting problems
mgb81
Post by mgb81 »
Still struggling with starting ! I ve changed the solenoid , its made no difference , I ve had the starter switch apart and checked that and the kill switch , I ve checked battery terminals , all good . I ve checked all fuses , all good .
Sometimes it will start and is fine , turn it off and back on again , all is fine . Come back the next day , ignition on , but bike wont start on the button . It will if you short across the solenoid ( not something I like to do ) Could the Alarm be causing this ?
Has anyone got any further thoughts on a solution .
Many thanks
