fuel system
Posted: 16 May 2017 20:08
by loki100
Hello everybody!
If I remove the tank, the fuel is running out.... Is it normal? What is close the benzin pipes? What should be the problem?
The other problem is that the oil level had grown up with benzin (smell). Have you ever met anybody with this?
Thanks in advance.
Re: fuel system
Posted: 16 May 2017 20:31
by backfat1187
If the tank is half full or above, quite normal.
When you tilt the tank back to remove fuel lines and electrical connector, fuel will run out through the breather.
Worth disconnecting the battery to make absolutely sure of no source of ignition.
Re: fuel system
Posted: 16 May 2017 20:36
by backfat1187
Never heard of the oil level going up like that on a fuel injected bike.
Could you have a leaky fuel line/injector inside the airbox which is running down into the motor through the crankcase breather?
Re: fuel system
Posted: 17 May 2017 09:17
by loki100
Re: fuel system
Posted: 17 May 2017 12:32
by MickeyMoto
Standard system or Termis?
My 06 had a good map, see posts from 3 years ago.
Mike
Re: fuel system
Posted: 18 May 2017 16:42
by loki100
I have GPR exhausts.
Re: fuel system
Posted: 18 May 2017 17:29
by MickeyMoto
Take it to a rolling road and have it mapped properly.
Ensure everything to spec first. Plugs, valves, air filter, injectors etc.
Re: fuel system
Posted: 18 May 2017 20:11
by loki100
where can I find the earlier post?
-I need it for my 2008 corsaro1200-
THX
