Wiring Diagram
Musclemoto
Wiring Diagram
Post by Musclemoto »
Would anyone have a wiring diagram for the Scrambler 1200? It would be of great help as i want to check if an alternative to the factory regulator can be used. There is a reliable Mosfet supplier in the States and he requires the wiring diagram just to make sure it would work for the Scrambler.
twisty
Re: Wiring Diagram
Post by twisty »
since the bike is just a derivative of the corsaro then that models wiring diagram will not be much different.
There is a wiring diagram if you look through the links on the corsaro site which shows a download available from the german forum . ( For some reason the wiring diagram is not in any detail in the corsaro workshop manual, in fact i think it is missing).
if i find it i'll post it below
this was the link
http://www.ital-web.de/forum/viewtopic. ... b64591cac6
BUT
the files have obviously been upoaded to a file server that is now time barred and they are no longer avalailable unless someone took a copy of the original files before they dissapeared.
Try posting on the corsaro forum or on www.ital-wed.de for help
