250 2C instrument surround
250 2c- the Wee-WeeVees
BarryCambs
Post by BarryCambs »
Hi all
The plastic on the clock surrounds has started to dsintegrate with age and one of the mounting holes has now broken up completely.
Do you know if these are the same as any other model, so I can widen my search?
Many thanks!
Barry
mbmm350s
Re: 250 2C instrument surround
Post by mbmm350s »
Hi Barry,
The same instrument surround was fitted to the 250T but that's even rarer.
Better is that you can use the surrounds from the 83-86 X, X1 and X2 Kanguro 350 and also Camel 501 models.
Part number is the same 32.01.22 (which replaces the earlier 250 2C/2T part) - again an example of Morini re-using part numbers.
The mounting distance on the top yoke is the same and the clock fitting is the same.
These will give extra idiot lights one of which can be used for indicator repeater for example
The ignition switch should fit OK.
importantly they seem to be more reinforced around the switch area.
We have a 501 camel version on our 250.
'It must be a .....'
The Mk2 onwards Camel twin shock 500s all use the same instrument surround
BarryCambs
Thanks for the great information.
A quick searck on Mdina Italia with the part number doesn't show anything. Do you happen to know if they are stil available new from anywhere?
Barry
