Strada MK5 (1979/80) Fork Seal Size
funsize
Post by funsize »
Evening all
All my parts guide/blue book says is 35mm. I’m sure they’re 35-47 but there seems to be either 7 or 10 as the final number (height). Can anyone confirm the correct ones before I order?
Mdina seem to have 3 possibles, including Pantah ones. I also understand you need 2 per side. I’ve only had one side go but have seen kits with dust seals etc and am thinking just do the lot when I’m sure which one..TIA
Re: Strada MK5 (1979/80) Fork Seal Size
35 47 7 two off each side.
funsize
Post by funsize »
Many thanks Mickey :D
As Mikey said, 2 of 7mm was the original spec. With decent modern fork seals I use 1 of 10mm seal. They usually have a wiper lip as well as a sealing lip.
funsize
Post by funsize »
Thanks Steve, good to know. I already got these from eBay which should be fine for both sides, but I’m also going to have a good look at your suggestion also
35X47X7 Pack of 5 OILSEALS, Metric Shaft Oil Seal 35mm ID x 47mm OD x 7mm wide
