Any one know the available valve sizes for the V-twins?
350's were Intake 30.5mm Exhaust 22mm
What size were the 350 Darts valves?
And the 478 and 507's???
Valve sizes
Re: Valve sizes
dart 400 30.5 and 22.5
Re: Valve sizes
If you go to my blog at: motositaliana.wordpress.com and then go to the morini tech section you will find the valve sizes for all the models apart from the 500 (if anyone has the size of the valve head for the 500 could they send them to me. ). I am trying to build up a data base of info about the morini's for other owners that at the moment I can't find on the net. I also own a couple of round barrel guzzi's and after owning them for about 9 years and being able to find out any info I needed with very little difficulty Iam really suprised at the lack of basic info on Morini's.
My sites all a bit mish mash at the moment, but once I build up enough info and have enough time I will re-order it with more clarity.
Hope this is of some help.
Andy
Andy
Re: Valve sizes
500 inlet: 32mm
500 exhaust 26mm
501 inlet 34mm
501 exhaust 26mm
500 exhaust 26mm
501 inlet 34mm
501 exhaust 26mm
Re: Valve sizes
Thanks for that. I will post it on my blog (I already had the other sizes from the heads I have). I am also collecting bearing referances to post in a section. So if anyone is taking a wheel bearing out or completely stripping their motor, if they could write down the bearing ref's and send them to me at : motositaliana@yahoo.es .
I am hoping to build a referance section on the blog for all cosumables and any hints or tips.
Andy
Andy
