When my sport engine is running whether hot or cold it is near impossible to get it back into neutral any ideas what to look for ?
Thanks in advance and I will report back .
Mikey
MarkB wrote:It's always difficult to find neutral if you're stationary; it's much easier to tap it in while you're still rolling.
pedro wrote:I had this problem and could not seem to overcome it, however, on putting a new set of clutch steel plates in (not expensive) the problem disappeared. Any slight warping will make neutral selection impossible.
3potjohn wrote:I can find neutral but not always and when I do it never feels a very positive so when i let the clutch out I expect it to be in gear. I have relatively newish clutch plates, The gear lever is a bit wobbly on its pivot. I've tried shimming the clutch.
mgelder wrote:Cutch (and rearset linkage) adjustment help, but I've never found finding neutral an issue on mine. Is this something I now need to start worrying about?
72degrees wrote:mgelder wrote:Cutch (and rearset linkage) adjustment help, but I've never found finding neutral an issue on mine. Is this something I now need to start worrying about?
No. "If it works don't fix it"
MickeyMoto wrote:72degrees wrote:mgelder wrote:Cutch (and rearset linkage) adjustment help, but I've never found finding neutral an issue on mine. Is this something I now need to start worrying about?
I have thought long and hard about the above. Is Martin's bike 'fixed' as it selects neutral easily or 'broken' for the same reason? Surely it has been modified from standard and therefore nowt to worry about! Am i 'clutching' at straws?
Just ride!
Just ride!
Users browsing this forum: No registered users and 5 guests
