End-float
Lewes96
End-float
Post by Lewes96 »
I have about 1mm end float on the front chain sprocket. Normal?
mbmm350s
Re: End-float
Post by mbmm350s »
Assume you have no other play in the bearing and the nut is tight. The 350 I just looked also has end float.
Lewes96
Re: End-float
Post by Lewes96 »
No all right so will probably leave as is
