Electric start.
Electric start.
Hi all, just rebuilding the starter motor on my 350K1 sport. Can anyone tell me the purpose of the eccentric grip-part 4 on the parts list (150675). Also, I need the cover bulkhead part number 150541. Mine has the lower lug snapped off. It might be secure with only the top bolt in but if there is a good one out there that would be better. To be honest it all looks a bit heath robinson in the casing with everything in there, no wonder I see lots of damaged casings!!! Many thanks.
Re: Electric start.
Hello Tim,
without looking at the parts list I think you mean the short m6 bolt with an eccentric collar/cam that screws into the outer cover.
The starter motor hinges on the long m6 bolt and once everything is in place you can adjust the tension on the drive chain by turning the cam against the starter motor body. I hope i'm making things clear!
