carb issue
dunk 1
carb issue
Post by dunk 1 »
Hello - have finally put the bike back together after its partial resto!. Was most surprised when it started after a few kicks as was sure my rewire was going to raise a few issues. As part of the process I had replaced the pads in the choke/enrichment levers and put in smaller idle jets - so long ago I can't remember which size I plumped for without checking. I have only given it a very rough set up to get it started but am wondering about the choke - on left side it is needed to start but then overrevs massively and sounds like it is speeding up - after starting if I turn the left off and leave the right on it idles fine. Both off it stalls but if I turn the left on the problem comes back - it really is racing but fine with choke off - any ideas - Duncan
dunk
Re: carb issue
The enrichment lever raises a plunger that not only uncovers the end of the starter jet, but also uncovers an air passage to give a fast idle.
Richard
Re: carb issue
Post by Richard »
Sounds like my K2 which I normally start with only one choke on, but sometimes use two if very cold weather and then knock one off immediately it starts.
Stubaker58
Re: carb issue
Post by Stubaker58 »
It is possible to put the slides in back to front and this can lead to the revs building and building, not a nice thing (don’t ask how I know). Maybe worth checking?
