Morini Speedo drive
Posted: 19 Sep 2021 16:09
by Carts
Hi
Was after some thought from the forum. The Speedo on the bike stoped working, investigation found out the crown drive on the hub is worn out. Is this a known fault. The mechanic who look after the bike has got a new one he’s currently fitting, but I’m more concerned how it happens I. The first thoughts is I didn’t local the wheel properly with the drive end cap and this caused the wear. Just don’t want it to happens again
Cheers carts
Re: Morini Speedo drive
Posted: 20 Sep 2021 22:22
by George 350
Hmm. Worn out speedo drive? Mine is currently at 98000 and something miles and over 40 years old and is perfectly fine, but as the only owner I have occasionally stripped and regreased mine over the years. First thoughts are that sometime in the bikes life the grease has been washed off the gears (perhaps during a tyre change?) or the gears have never been cleaned/regreased.
There is no 'locating' of the drive required -its not like a Jap or Brit bike with lugs needing engagement -the wheel spindle does that job for you.
Only other thing I can think of is if someone has installed new wheel bearings and not cleaned the hub properly first, resulting in a cracked gear on the wheel hub.
If both the drive gear AND the driven gears spindle are greased well, there is no reason to believe that the gears won't outlive you!
Regards, George
Posted: 21 Sep 2021 19:50
by Carts
Thanks George for your comments, wheel has been on and off a lot over the last year. Problems with front disc. From your reply and nobody else saying they’ve had a problem I know it’s not a common fault, will have a good look at it and make sure plenty of grease on the parts when I get it reassembled
Thanks again.
Posted: 22 Sep 2021 12:18
by Vitesse
I do recall the first time I took the front wheel out. I was amazed that there was no locating lug and wondered if mine was damaged! Quire feasible for someone to have stressed it by allowing it to rotate whilst doing up the axle. I'd expect the cable to be what gives but I guess if that seized it could cause the gear to strip.
Posted: 23 Sep 2021 11:26
by Carts
Thanks Vittesse
Will check that cable rotates freely, I would of thought the cable would have been damaged first but worth a look.
