Morini 3.5 K (1982)
Hi all, my brake bleed nipple is leaking. Its a Grimeca caliper on left hand side. Went through the whole system looking for a leek then of course its right at the opposite end where I started! . I have seen this topic mentioned somewhere so I guess its a common fault. Anyone know the cause/remedy here?
Thought I'd try you guys first, as daytime calls to NLM from Ireland start adding up after a while
cheers John O'Eekzoids
brake bleed nipple
bleed nipples
not my original posting but...this does beg the question, can I replace the old style bleed nipple/ball bearing combo with a normal bleed nipple in the same Grimeca caliper? Thanks, Stuart
brake bleed nipple
Thanks for that info..I had no idea about the ball bearing thing. I shall investigate further.
Is there a workshop manual for 3.5? I have the blue manual thats bi lingual...don't think it discusses brakes in that much detail, didn't even think to look..I'm used to small jap bikes before this and they are all pretty similar.
Does Clymer do a manual perhaps?
