I have a few bits of 500W left over here and I would like some space too! So please consider the following. I'll add some more over the next few days as I sort through. Ask if there is anything you are looking for as I have loads of little bits and bobs, brackets etc.
Brake discs, 3 of all in need of a quick clean but would skim nicely too. Each disc £25 posted in UK.
Rear brake Caliper, 1 of, needs a good clean and would be sensible to reseal of course. £50 posted in UK.
Front brake caliper, 1 of, similar condition to the one above. Same type as 350 Strada/Sport. £50 posted in UK.
Front brake junction box for 3 hose system. £15 posted in UK.
Rear wheel Cush drive assembly with rubber and sprocket. £35 posted in UK.
Alloy kickstart extender block (no pivot pin) used £10 posted in UK.
Front engine plates-ALLOY diy job but not bad £15 posted in UK.
Front engine plates steel original for KINKY frames need clean and paint. 350/500 road models £15 posted in UK
Steel Instrument bracket 350/500 road models earlier type, needs clean/paint includes one black plastic clock binnacle thingy. £15 posted in UK.
Rear brake master cylinder and reservoir for 500W/later 350-needs overhaul piston stuck. £15 posted in UK.
Camshaft used 'S' sport type in good serviceable condition. £50 posted in UK
Camshaft used 'E' type in good usable condition. £40 posted in UK.
Camshaft used 'L5' type PATTERN but very good condition. £50 posted in UK. Under offer!
Primary drive cover all 350/500 with oil pressure switch hole £40 posted in UK.
Ign.Pick up cover with rev counter drive. all models with cable drive tacho. £25 posted in UK
Rev counter, cable type, black face, 8,500rpm redline. £35 posted in UK.
Primary drive gear set 350 models. £45 (Heavy!) posted in UK
Battery carrier 350/500 electric start models. £15 posted in UK.
350 silencer brackets 1 pair. £10 posted in UK.
Rear caliper mounting bracket alloy 350/500 road models. £ 20 posted in UK.
Mounting bolt and spacer for 350/500 1st type disc caliper. £5 posted in UK.
Clutch outer alloy basket. 350/500 all models. £15 posted in UK.
ALL THE ABOVE ARE IN USED BUT USABLE CONDITION, AND ARE AS REMOVED FROM BIKES BY OTHERS, NOT CLEANED SO EXPECT A BIT OF SCRUBBING/PAINTING REQUIRED!!
More to come as I sort through what's left over.
PM me with your email address if you want pictures. I'm in South Leicestershire, not far from M1 Junction 20 or 21. Arrangements can be made for covid safe handover if you are able to collect.
500W used spares
500W used spares
