I have just bought a bulk load of mostly NOS spares. I've looked through it to see what I should keep for spares, but much isn't correct for my bike (or there are multiple same parts so I can let some go).
So here is a list....
Rear light lens (NOS)
Front sprocket x 2 (steel) 14T (NOS)
Clutch plates (thick 21.01.25) x 5 (NOS / surflex )
Clutch plate (thin 20.01.24) x 1 (NOS / surflex)
Speedo cable (NOS / cagiva packaged)
Cambelt (NOS / Goodyear)
Rear brake cable with inline switch for rearsets (New / Venhill) (but may instead fit it and sell the NLM fitted item)
Rear Sprockets x 2 , alloy (36T / 37T, new) 6 bolt fitting (I need 5 bolt fitting, will happily swap!)
Valve inlet? (16 01 18) NOS Cagiva
Valve Exhaust NOS Cagiva (no part no.)
Valve springs x 4 NOS Cagiva part 22.01.53
Rubber intake manifold coupling (30.01.55) (I have original alloy carb inlets)
Complete front wheel brake plate complete with shoes (as new) and levers / cams etc (brake plate 43.05.15) (I have disc wire wheels, this is for Strada wire wheel I beleive?)
Also have complete SPORT bottom end (complete including casings and upto and including pistons) used, but beleived to be good working order. Undecided whether I should keep or sell (I paid £1100 last year to have my engine rebuilt, so a) it shouldnt need rebuilding again but b) If it did I'd be gutted that I'd sold this!)
pm me or call me on 07917 248529 (Stuart / winchester)
