various Morini parts
hombre
Post by hombre »
Wheels, frames, engine parts etc: see listing here: https://www.marktplaats.nl/verkopers/487486.html
A friend is in London the 27th and can bring parts across the channel to save on postage cardboard etc ;)
hombre
Re: various Morini parts
Post by hombre »
Just put some (new) parts up for sale, frames, engine parts, loads of stuff: https://link.marktplaats.nl/m1413308328
huub
Post by huub »
is the speedo drive complete with both gears?
i'm missing the wheel side gear in my drum 350 sport.
hombre
Post by hombre »
Yes both gears are here, but if they will fit your bike I am not sure. I'll check for measurements etc. and let you know.
hombre
Post by hombre »
On the wheel side it says 29500-201-016, on the other gear is just "Veglia"
Sizes are ø outside 50mm, the gear side, 51mm the flat side with a small recession in the middle
ø 47 mm inside
height 21 mm
I checked with the castwheel GT and they are interchangeable.
I have another one stamped 29500-201-019 Veglia (only the wheel side), don't know where that one is from but the measurements are the same.
huub
Post by huub »
it is for a drum 350 brake sport ,
i have the wheel ,and the external gear, but not the gear fitted to the hub.
i'll check this weekend if it measures up.
