No, not all models. Some of the later ones had a breather catch tank where the main breather is connected as well as the two rocker cover breathers. (The rocker covers have their own little labyrinth and nobody seems to lose or damage them) the catch tank were also connected to the airboxes to reduce the pressure in the breather catch tank and recirculate the gases from the crankcase.Zed1 wrote:Should all models have these ? I've a Excalibur and when I swapped the breather tube it was just a empty tube ,if needed would 1 of the non-return valves be ok thanks Paul
Yours will only need either a labyrinth or a check valve if you don't have the catch tank connected up.
