No harm in asking.... Im after brake and clutch levers and mounting brackets for the Morini drum-brake 350s..even one would be a start
Simon in the UK
email: moriniboy23@yahoo.co.uk
DRUM BRAKE MORINI LEVERS AND MOUNTS
Re: DRUM BRAKE MORINI LEVERS AND MOUNTS
See this thread:
viewtopic.php?f=6&t=4562
The mounting brackets for the clutch lever/front brake lever on 1975 Sports and Stradas are the same. Also, the clutch and brake levers will be the same.
Yes I know what they look like - chrome, with LHS tapped-holes for the snuff-box switch but I need to find some!
I must have a Verlicchi clutch perch with CEV 169 snuff box somewhere:
tomros@live.nl
For the right side (or do you also brake on the left over there?) you must look out for Benelli 250C/ 650 Tornado, or Laverda 650 GT item.
tomros@live.nl
Yes please Tom, Ill have it. I have emailed you
Simon
Simon
Simon
Simon
You drive on the right side we drive on the correct side. I can draw my sword but the throttle keeps closing...Tom wrote:
For the right side (or do you also brake on the left over there?)...
