Clutch holding tool
Matt Hale
Clutch holding tool
Post by Matt Hale »
Hi All
I wonder if anyone knows how I could get a clutch holding tool for. 350 Sport ? I need to remove the clutch drum+ as the kickstart is making a noise and I need to check the mechanism behind the case. I’ve tried buying but none in stock anywhere I can find. I could make a tool using a clutch plate maybe but I haven’t a spare plate. Any ideas on the tool or kickstart issue welcome!
Many thanks in advance
Matt :)
350 Sport 1979 electric start model (missing)
Curry yellow tank etc paint work, navy blue frame, silver wheels.
hombre
Re: Clutch holding tool
Post by hombre »
If you cannot find one closer to home I can send you a spare clutch plate, pre-drilled even ;)
I have two of those tools but on one the lever is bend :/
