I find I am missing the washer part No. 43.05.49 OR what dimensions is it?; and the speedo drive seal part No 43.07.15 (assume I might get away without this, but debris gets in?) OR again its dimensions.
If anyone can help, thanks
Richard Parker
250 2c front wheel washer/seal
- Parker3865
- FrtWhl details.jpg (47.63 KiB) Viewed 3893 times
Morini 250 2c currently rebuilding from a box of bits.
Re: 250 2c front wheel washer/seal
I may have one. Is it for the large diameter shield (the casting with the ’beak’) or the smaller?
The part 16 43.05.49 is just a shield for the usually fitted unshielded bearing, if you fit new metal shielded bearing then its not needed, notice the other bearing is described in Italiano as schermato this means shielded.
If you already have fitted an unshielded bearing then its best to fit a shield, I will look for one if you need.
- Parker3865
Have fitted shielded bearings thanks. So you reckon all will be ok? Many thanks
Yep, no problem part 16 not required with ready shielded bearings.Parker3865 wrote: ↑01 Dec 2023 17:10 Have fitted shielded bearings thanks. So you reckon all will be ok? Many thanks
Cheers Mark
- Parker3865
