250 2c front wheel washer/seal
Posted: 30 Nov 2023 16:23
by Parker3865
I find I am missing the washer part No. 43.05.49 OR what dimensions is it?; and the speedo drive seal part No 43.07.15 (assume I might get away without this, but debris gets in?) OR again its dimensions.
If anyone can help, thanks
Richard Parker
Re: 250 2c front wheel washer/seal
Posted: 01 Dec 2023 06:02
by Ming
I may have one. Is it for the large diameter shield (the casting with the ’beak’) or the smaller?
Posted: 01 Dec 2023 16:15
by mbmm350s
The part 16 43.05.49 is just a shield for the usually fitted unshielded bearing, if you fit new metal shielded bearing then its not needed, notice the other bearing is described in Italiano as schermato this means shielded.
If you already have fitted an unshielded bearing then its best to fit a shield, I will look for one if you need.
Posted: 01 Dec 2023 17:10
by Parker3865
Have fitted shielded bearings thanks. So you reckon all will be ok? Many thanks
Posted: 02 Dec 2023 09:34
by mbmm350s
Parker3865 wrote: ↑01 Dec 2023 17:10
Yep, no problem part 16 not required with ready shielded bearings.
Cheers Mark
Posted: 02 Dec 2023 16:27
by Parker3865
Goodoh!
