For information to anyone else looking for one of these switches.
I damaged my switch and was told by NLM that no replacements were available. I found a CEV 206 switch on eBay that looked almost identical.
I have now finished the wiring and can confirm that the switch is correct, but needs a small modification. The new switch had one less wire and a different connector block, which means the finished job requires some customised wiring.
The extra wire has to be soldered to a spare terminal on the main light switch, which is accessed by dismantling the switch unit.
Also, a point to note is that the wire colours are completely different on the new switch and so each wire has to be matched to the equivalent wire on the old switch.
Replacement Light / Indicator / Horn Switch
