Bleeding Rear Caliper
snatchpiece
Post by snatchpiece »
I'm fitting a replacement hose to the rear caliper and I've noticed there are 2 bleed nipples, do you have to bleed them both simultaneously? if not does it matter which one you do first?
1980 Moto Morini Strada 500
enfie
Re: Bleeding Rear Caliper
Post by enfie »
Nope, one at a time, I think they are both equidistant from the hose input, so bleed new fluid through each nipple until no air bubbles are visible.
Cheers, Enfie.
snatchpiece
enfie wrote:Nope, one at a time, I think they are both equidistant from the hose input, so bleed new fluid through each nipple until no air bubbles are visible.
Cheers, Enfie.
Thanks for this, it worked a treat.
