I am making an extracter for this cover, does any one know, what size thread is in the cover.
Eric.
generator cover extracter
Re: generator cover extracter
I presume you mean you are planning on making a flywhee/alternator puller.
Unless you're going to make one in heat treated alloy steel, I wouldn't bother, they're less than £10 to buy ready made.
If you really want to, then the thread is M27 x 1.25mm close tollerance.
Hi Paul,
Thanks for the info, I like making service tools.
Measured thread today, and you are correct M27 x 1.25 mm pitch.
Will make it a good fit, in the cover/flywheel.
Thanks, Eric.
Thanks, Eric.
