Changing fork seals on the 500
Postby Treebod » 24 Apr 2018 21:20
Hello, please can anyone give me tips on how to change the fork seals on the 500,there are no dust caps/collars on mine and seemingly no circlip, just a metal insert sitting on top of the seal, is this usual,any ideas would be welcome. Thank you.
Treebod
Re: Changing fork seals on the 500
Postby Pilbeam1 » 25 Apr 2018 08:33
If they are Marzocchi that metal collar should have a small slit in it at a diagonal to the circumference.
Just use a small screwdriver to get out the clip, it can be a bit of a pain.
Then you can pull out the seals.
Pilbeam1
Postby Treebod » 25 Apr 2018 19:51
Many thanks, i will give that a try
Treebod
Postby Canuck750 » 03 Sep 2018 14:31
Canuck750
Return to The 500
Who is online
Users browsing this forum: No registered users and 2 guests
