I’ve finally removed the petrol tank ( what a struggle, I think the cups that seat on the rubber pads were catching on some cable clips), how on earth do you access the air filters? do you have to remove the carbs then remove the air filter casing?
I’ve done a search on “air filter” but it didn’t yield the info I require.
Thanks in advance,
Mick.
