Veglia speedo repair
Re: Veglia speedo repair
Hi Ming,
I've tried messaging but not seeming to work, am still keen to secure the Tacho, hope you still have it.
Email. mga.goacher@hotmail.co.uk or 07866 521955.
Graham.
Graham.
Ditto for me with SpeedyCables - they take twice as long as promised (a bloody long time) and when it did come back the electronic-tacho was reading at half-speed - just like other people's on here, so theyve got no excuse for repeatedly making the same mistake with Morini tachos surely.
I wouldnt use them again
Yes agreed, if they have previous with our particular instruments they should not accept the work!
Graham.
Graham.
A quick update. I sent the clocks to Peter Bond (aka the gaugeman) and after 4 weeks, as per quote, they arrived back home looking like new. Peter Bond, has basically serviced the clocks, adjusted the damping etc so that pointer (needles) do not jump about, fitted new bezel, refurbed the faces and the pointers (or they may even be new), fitted some new internals and all looks good - see attached photos.
Not cheap but I think that the quality of his work is good.
Good luck in these difficult times and please take it (Covid-19) seriously,
Charles
Charles
- Sideview to show the new trip reset made by Peter Bond - he needed the mounting pod to ensure the diameter of the reset know were correct.
- Refurbished clocks_new speedo trip reset_IMG_2286.jpg (175.08 KiB) Viewed 7493 times
- As you see them when sat on the bike
- Refurbished clocks_IMG_2285.jpg (188.14 KiB) Viewed 7493 times
Looking good there...
Expensive? Probably not if they work.
Stay At Home! As much as I would like to see people, I'd rather see you in six months than never again!
Well thanks Mickey, very kind of you - this social distanceing is obviously softening you up.MickeyMoto wrote:Looking good there...
Thanks,
Charles
Steady on...
I do not intend publishing any photographs of my backside flouncing around on this forum!
Hello Charles,
The clocks look fantastic, if that’s the standard of Peter Bonds work I think that I will send him my 500 clocks.
Regards Pete.
Regards Pete.
I think that Peter's work is good - the proof of that will be in the longer term when the clocks have been put to good use; until then, I would have no qualms in using him again, in fact he has my Moto Guzzi clocks now that should be wending their way back to me any day, postal service permitting.
Adios,
Charles
Adios,
Charles
Both my speedo and rev counter have badly faded dials. Does anyone know whether it is possible to source replacement dials, as part of the refurbishment process? I know that screen printed dials are available for certain classic car gauges.
They look superb!Peter Bond, has basically serviced the clocks, adjusted the damping etc so that pointer (needles) do not jump about,
Luckily, mine have never really been 'vague liars'. I haven't had them serviced but noticed a positive change to needle-smoothness once I'd fitted a new speedo cable and routed it properly. Made a huge difference. My tacho has always been pretty smooth.
Something to bear in mind.
DD½
I had two tachos done by Speedy Cables. Nothing Speedy about them, apart from the name, and BOTH came back reading at half-speed. The first time I thought was a fluke.
Looking on here, its obvious SC make the same mistake on Morini tachos over and over again, and have had multiple people sending them back, with several months wait (again). Never again
At least in the electronic tachometers and I don't think the mechanical Veglias are any different, there is no adjusting of the damping, except by using a different oil. The oil is in a cup beneath the lower shaft bearing. The reason the damping fails is that the very high viscosity damping oil evaporates, oxidises, or simply leaks out over time.Seagreen wrote:adjusted the damping etc so that pointer (needles) do not jump about
Charles
