500 & 350 brake pads
Posted: 03 May 2021 14:53
by Seagreen
Does anyone know whether the brake pads fitted to 350 Sport and 500 Sport models are the same?
Thanks,
Charles
Re: 500 & 350 brake pads
Posted: 03 May 2021 22:42
by Daddy Dom
Possibly. However, they used different Grimeca calipers from around 80/81/82 onwards. Can you post a photo of your calipers?
DD
Posted: 04 May 2021 08:15
by Seagreen
Hi DD,
Thanks for your reply; please find attached 3 images of the front calipers - hope that these help but if insufficient clarity etc please let me know.
Ciao,
Charles
Posted: 04 May 2021 22:06
by Steve Brown
Those are the earlier type calipers as fitted to the 350s too. From 1976 till they went to the later type. FA76 is I think one manufacturers code for them. I can check tomorrow as I have just bought a set!
Posted: 05 May 2021 05:41
by Daddy Dom
Yep, you should have heaps of choices for those.
Posted: 05 May 2021 19:49
by Seagreen
Hi Steve and Dom Daddy,
Thanks for your replies and, Steve, I look forward to getting confirmation on the code when you have been able to check.
Kind regards,
Charles
Posted: 05 May 2021 21:29
by Steve Brown
Yes, I forgot that! EBC code is FA076 and you should be able to cross-reference that to other makes.
Posted: 07 May 2021 08:45
by Seagreen
Thanks Steve. I will check the EBC site and see what it offers. Thanks again for taking the time to check, it is much appreciated.
Adios,
Charles
Posted: 10 May 2021 17:57
by JonnyP
On a similar point, when I stripped down the calipers on my 1978 500, I noticed a small spring clip which I assume was fitted to stop the pads from rattling. However, the replacement pads I've bought from Mdina do not include these clips. I haven't got around to reassembly yet, but are these spring clips necessary?
