Anybody has got a wiring diagram for the 500 camel?
i am fitting a three fase stator and regulator to get rid of the weird 6/12 volt electronics,
the stator and regulator is no problem, but to change the rest a wiring diagram would be nice.
wiring diagram camel
Re: wiring diagram camel
Hi, it's easy to use the existing wiring harness when converting to a 12v: connect into the existing 6v DC circuit then connect the 12v AC wire that feeds the light switch (handlebar) into the DC circuit at the junction/fuse box behind the side panel. Change the bulbs and fit a 12V battery; making a new battery carrier is the biggest job.
I can send you a copy of the standard Camel 500 wiring diagram If you send a me PM with your contact details.
It really is that easy, regards Ian
PS What stator/regulator are you going fit?
I sent you a Pm for my email,
i fitted a stator i bought on aliexpress, as i dont need the high tension coil i might as well fit new parts.
i did a search for 93 mm stator , and ended up with this:
https://nl.aliexpress.com/item/Motorcyc ... 0.0.BgtS6E
the regulator is a shindengen bought on aliexpress,
https://nl.aliexpress.com/item/Black-Mo ... 0.0.Ih0dbY
i am waiting for the HT coils i ordered in china, so the first test ride might take a couple of weeks
Nice Bike! Good bit of parking too...
thanks, my house used to be a art gallery,Haboola72 wrote:Nice Bike! Good bit of parking too...
i haven't got a art collection , but i've got old bikes instead.
works for me...
