carb pipes on my 350 Kanguro
Posted: 12 Oct 2018 15:56
hello I hope somebody can help me out I bought the bike as a non runner, filthy carbs no spark. Years of neglect. I have managed to get a spark front and back.and moved on to the carbs. I have cleaned them but have no idea where the three smaller tubes go, I have a GS 1000 that has breathers, and overflow tubes and a vacuum release to the tap, is this set up the same... and which is which ? each carb has one small pipe at the front and one either side of the slider tower, I take it the large pipe with banjo is the fuel feed...any help would be gratefully received. And while I have your attention I have an issue with the ignition that seems only to create power when turned to the left ! is this normal, I don't think it can be cos there is a click to the right too, I am less worried about this, as I can replace the ignition barrel if needs be.. but just wondered what is standard. thank you. Simon
39 views and nobody knows anything.!!
