'It must be a .....' wrote:It is quite easy to fit the large tank on the earlier square tube frame Kanguro by fabricating a front mount (bolt on or welded), yet fitting the small tank on the later frame requires the removal of the welded on front mount (the smaller tank's mounts simply bolt on) and finding a new location for the larger battery, There are no issues with the air box etc.
Sorry but I have no experience of the initial round tube Kanguros X/X1 but I think the air box is the same?
Hope this helps, have fun
This is a note from an old thread "X3 carbs", but other owners may be interested in what I've done with my X1.
My missus has a 3 1/2 strada, and when ridden back to back, despite the lower gearing my recently acquired X1 felt a bit "flat" even after a full service.
I wondered why - given the engines are much the same and the carbs and needles are similar. On doing some research, it seems all the Kanguro, Dart and some of the Excalibur models run much smaller main jets as http://www.motomoriniclub.nl/carb.html
I thought about fitting k&n filters & rejetting as the other bike, but given the planned mudplugging duties decided against. I fitted 112 strada mains, but it was HORRIBLE & wouldn't rev at all, so clearly over jetted. As the Strada airbox is actually smaller in volume, logic told me something was up. I found this:
http://www.compton.vispa.com/morini/dartmods.htm
It is clear from the pictures that the Dart. Excalibur and Kanguro all use the same "tube" airbox design.
Once the "flower pot" is removed as shown in the link, the bike can be set up as a 3 1/2 Strada. I didn't modify the inlet tubes, just whipped out the flower pot. Wow, way more get up and go, the flat feeling has gone and it's much more lively.
As the airbox is under the tank, I don't think there's much reduction in air cleaning as the standard filter is retained and this is an easy fully reversible modification to liberate a few more ponies.
