Grimeca front brake calliper.
Hello all,
after battling with the front disc callipers all day, I am in nead of one calliper, got one working ok the other one is seized solid,had it immersed in plus gas for weeks, tried heat today and the pistons still won’t move, so has anyone got one for sale, or got any good ideas on how to get the pistons out ?
Regards Pete.
Regards Pete.
Re: Grimeca front brake calliper.
Compressed air, but high risk if it is really seized up.acemorini wrote:Hello all,
Regards Pete.
David
air is too dangerous, try fill most room with a liquid before you apply any pressed air.72degrees wrote:Compressed air, but high risk if it is really seized up.acemorini wrote:Hello all,
Regards Pete.
I have had success with a gear grease gun, you just have to make a converter so you can mount a grease nipple to the caliper
Thanks for all the reply’s, I have tried air but no luck on this one all though I have had success before, might try the grease gun method this week and order one of the piston removal kits as recommended by Buzby. Let you know how I get on.
Regards Pete.
Regards Pete.
This worked for me recently, but it wasn't too badly seized even though the bike was standing for 20 years.
I reassembled with hydraulic line and reservoir and brake lever and clamped one of the pistons (the one that was moving a little) with a clamp like a g-clamp . I was then able to pump the other one out.
I wouldn't employ too much heat as it could damage the seals and may be these are difficult to get.
Again you could gently try to push the piston back in with a clamp to get it moving
I only used compressed air once, it scared the crap out of me when it came out even though I buried the caliper under a pile of rags, and i never want to do it again
PANG!!!!
What, use Chris Patton to remove the pistons?Tom wrote:PANG!!!!
Update on the brake calliper saga, the piston removal kit turned up today and removed one of the stuck pistons easily, the other one would not move it was solid like it was welded in, went to see my mate at his garage airline homemade adapter into the calliper and piston out in less than 1 second, morale of the story don’t much about just go and see your mate in the garage.
Regards Pete.
Regards Pete.
Told you "PANG!!" is the only right sound
More of a BANG than a pang.
Regards Pete.
Regards Pete.
