Cam Belt Size
snatchpiece
Cam Belt Size
Hi, its time to replace the cam belt on my 500 Strada, I can't for the life of me remember how to determine if I need size A, B or C.
Is there anybody out there that knows ?
Thanks in advance
Mick.
Thanks in advance
Mick.
1980 Moto Morini Strada 500
Re: Cam Belt Size
Yes, the camshaft pulley should have the A B C marking stamped on it. All in the manual, easy to do.
Re: Cam Belt Size
An if there is no letter, it´s a "B"
SupermotoDave
Re: Cam Belt Size
And pattern belts are all Bs anyway, unless they’re not.
Re: Cam Belt Size
SupermotoDave wrote:And pattern belts are all Bs anyway, unless they’re not.
Only the pulleys of the first series motors don´t have a letter A,B or C and have the norm-size B,
Re: Cam Belt Size
The majority of timing belts will be 'B's since that size sit right in the middle of the production tollerances.SupermotoDave wrote:And pattern belts are all Bs anyway, unless they’re not.
Look up 'Bell curve', 'Normal', or 'Gaussian' distribution
snatchpiece
Re: Cam Belt Size
Thanks guys, my manual has been returned to me and everything is clear now.
How do you guys prevent the rotor from turning when undoing the nut, do you all have the special tool?
Re: Cam Belt Size
You can make that tool easily yourself. Two pieces of steel or strong alu, three screws and three nuts
Maybe you have to tune the two srews/bolts that enter in the flywheel (this one is for the newer flywheels). Leave one arm long enough to settle un the footrest
On the road you can put the 6th gear and juse the rear break.
Re: Cam Belt Size
About to fit a new belt to mine too. Are 'Gates' belts good quality ?
Re: Cam Belt Size
I think any belt you buy from a Bearing Factor, or on line from a reputable company like RS will be at least as good as an 'original' which was more expensive due to them being measured and graded.
Quite possibly any modern belt will be made from better quality materials, too.
osborne4121
Re: Cam Belt Size
I saw that the ‘Morini’ belts are around £30 yet the industry standard ones are as low as £5. Is this false economy? They are made by well known companies like Dunlop or Continental.
