Kanguro X3 Rear Indicator
Hi folks,
Looking for a rear indicator for a Kanguro X3. Not too worried about the lens or case but need the rubbery bit as somebody who shall remain nameless broke it when invading the shed.
John.
John.
Re: Kanguro X3 Rear Indicator
I have box of indicator bits, can you post a pic of the part you are looking for?
Hopefully these images upload!! This is what I'm after - moral is don't let people move stuff in the shed!!
- Indicator whole S.jpg (25.83 KiB) Viewed 6786 times
- Indicator broken S.jpg (27.52 KiB) Viewed 6786 times
Looks the same as this Guzzi part from what I can see.
http://www.mgcycle.com/index.php?main_p ... ts_id=3319
Charlie Mullendore
It certainly does - thanks for the info!!
I'll have a hunt on the UK Guzzi parts sites as $39.95 shipping mad me gulp a bit!!
John.
John.
Hello John,
I think that I have one of that style left in the shed, I will have a look tomorrow.
Regards Pete.
Regards Pete.
Thanks Pete,
I appreciate that. If you do have one I'll nab it off you. I have found a couple on ebay for a reasonable price but they are based on the part number Charlie provided so they may not be the same so a bonafide kanguro one would be ideal.
John.
John.
Hi, I have some Excalibur indicator parts which are chromed plastic instead of black but they are the same as the X3.
If this is any good to you? I'll have a garage quest and check the condition of the rubber stems.
Take care, Ian
Take care, Ian
Thanks Ian,
It would be interesting to see if that is the case. Looking at the Guzzi parts there were chromed indicators that had black stems - perhaps Morini/Cagiva used the same suppliers.
Look forward to seeing what you find.
John.
John.
Hello John,
I will send you the indicator when the lock down ends.
Regards Pete.
Regards Pete.
Thanks Pete,
Look forward to receiving it (and seeing the end of lock down!!).
John.
John.
Roll on the end of the lock down.
