It's the same ? Can I use 3 1/2 rear shock absorber for 500 Model ?
Thank-you for your help
Rear shock absorber Morini 3 1/2 and 478 it's the same ?
Re: Rear shock absorber Morini 3 1/2 and 478 it's the same ?
I think the 3 1/2 shock is shorter... 295mm vs 320 for the 500
"Innamorato di vecchi motocicli Italiani"
OK ... Thank-you for your answer
- Site Admin
Yes, I know for sure: the 500cc shockabsorber is longer!!
On this photo you can see the 500cc shockabsorber is longer: http://motomoriniclub.nl/project89-a.jpg The 350 Sport with 500cc shockabsorbers.
After that I swapped them with a friend and got the correct lenght: http://motomoriniclub.nl/projres-01-a.jpg
Want to swap? I have a pair of brand new Hagon (320S16LR) shocks for the 500...
Really i have a problem with spring ... chromium plating it's not good ... and I had thought to replace with 3 1/2 spring .....
probably won't work... springs for the 500 are somewhat stiffer though they might be the same size..
if your 3 1/2 shocks are in reasonable shape I'm still in for a swap
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
