Projects?
Well there is my Project Kanguro Moto for one, currently in the last few weeks of build, have spent a year on it so far. Check out prev posts for story so far. Will post an update soon in the offroads bikes section. Picture of completed rolling chassis below:-
Robin
Robin
The frame is an early X1 frame, it still has round tubing. I was warned of a weak spot on the older frames where the rear footrests attach. I have removed the rear footrests and welded an additional bracing plate in their place. Currently fitting the front headlight, using a Suzuki SV headlight with brackets from a Suzuki Bandit. I have had to cut the brackets in two and shorten them by 40mm each but now they fit the Husqvarna forks. Should have some more pictures by the end of Sunday. MOT booked for 14th June so the deadline is looming.
Robin
Robin
boris tarpit
