PDF file
Re: PDF file
I doubt it as the file will be too big.
I suggest dropbox as a way of passing these big files around, I used it to share a Ducati manual a while back.
You'll need to set up an account if you dont have one and then just pass on the links to the file you have uploaded, it's quite simple.
https://www.dropbox.com/
