Hi all
I would highly recommend Granpasso ,Corsaro,Scrambler and other 1200 engine bikes to check your radiator cap function . After I changed my coolant I found the valve that is in the rad cap was not functioning .it was not letting in coolant to the cooling system .if the engine coolant were to drop ,you would not know as the expansion tank will read as full ! .a simple clean and blow through sorted it .
Safety warning Auctung!
butchamphib
Re: Safety warning Auctung!
Thanks toggy will check both of mine
