Handlebars
The Cagiva era Morinis
clanger9
Handlebars
Post by clanger9 »
Are new replacement Dart handlebars available anywhere?
They seem to be the same as Cagiva Freccia, but I haven't found a source yet...
Re: Handlebars
Post by morini_tom »
They are indeed the same as freccia. I've never seen new ones available, other than occasionalsy NOS ones popping up on ebay. Used Freccia ones are often available. I am not aware of anything off the shelf which is a direct replacement
Which part is it you need? the bar or the alloy riser? They tend to not like being parted from the riser as it's very thin and the risers are commonly cracked in that area
clanger9
Re: Handlebars
Post by clanger9 »
Thanks Tom! I figured as much. It's actually the bar itself is cracked around where it fits into the riser.
I managed to get a used Freccia one and it fits fine.
