I've searched the internet and this forum but couldn't find what I'm looking for.
- wiring loom of a Dart including ignition details
or
- schematics of a kokusan ignition systems, from sensor to coils.
I've also posted an advert in the 'wanted'section.
regards Anne
dart wiring schematic
Re: dart wiring schematic
check the wiring diagram for the cagiva elefant/ducati 750/ducati 900
they have the same ignition sytem
https://www.ducati.ms/threads/desperate ... -cr.87377/
https://www.ducati.ms/threads/94-900ss- ... ms.261457/
if you need more info let me know.
i can check on the dart at home.
There is a wiring diagram in the members area.
But I’ll send you an email with it.
What specific issue do you have? Quite a pool of knowledge on this forum I’m sure someone can help.
I find quite often that the dart looks corrode a long way down the wires, making it hard to satisfactorily repair.
I made a new loom for my dart about 10 years ago. Not overly complicated especially if you have an original to copy. Not had a single electrical issue since.
the issue is if the Dart has standard ignition coils, as used with contactbreakerpoints or are the kokusan coils in reality only transformers used with a CDI-type of ignition.
regards Anne
regards Anne
3 ohm primary resistance , so pretty normal coils.
which (without further research) is a bit surprising.
the kokusan fires ervery revolution, so a wasted spark setup. the charging time for a wasted spark-ignition at 8500 rpm is max 7,05 milliseconds. if you distract the 0,5 millisecond for the spark then it is even less. so the coil must be fully energized in 6 milliseconds.
a std 3 ohms-coil time to re-energize is at least 10 milliseconds. at least the std 3 ohms-coil I'm using on my BSA, MG and MM500. but these are all 2 revolutions per spark setup.
but I'll start with a std-coil and see what can be achieved
regards Anne
