Installed fog light from givi this weekend loos fine
thinking about connecting heated grips anybody know where the original cabeling or connectors are
I only found ons connector with tree cabels in it (under the controlpanel) is this the one or are it two independent ones?
heated grips cabling?
Re: heated grips cabling?
Hi
Hope this helps ,see links for heated grips wiring diagram and photos of wiring harness.
https://www.dropbox.com/s/7f814mldvot63 ... 5%2033.jpg
https://www.dropbox.com/s/78lswb0pxz1d2 ... 7%2031.jpg
https://www.dropbox.com/s/8g79pyr6x748z ... 8%2010.jpg
https://www.dropbox.com/s/gs2yob3wtyqcm ... 8%2039.jpg
Ps ,I think the throttle side grip is not fit for purpose. When I bought the bike ,the heated throttle grip was not working .the cable had broken where it exists the grip . The replacement has lasted 14 mths ,the cable on that has broken on the exit of the grip too. I had even strengthened the cable with insulation tape and it still broke . They are rubbish quality for the excessive amount they sell them for .
hi gianni,gianni wrote: thinking about connecting heated grips anybody know where the original cabeling or connectors are
you will find the connector behind the ride fuel tank cover. i hope my photos can help.
günni
- heizung7.jpg (114.82 KiB) Viewed 13535 times
- heizung1.jpg (197.54 KiB) Viewed 13535 times
sbarazzino 98, corsaro 125, corsaro 150, corsaro 1200, scrambler
thanks a lot !!!
I have a pare of aftermarket ones (oxford) connecting them tho these plugs with this info is easy
In this I can use the standard button than to controll them
Aftermarket and original ones both work on 12V so I don'think this will give problems
I will give feedback if it works
feed back will take some more time .....
stupid accident yesterday
standing still behind a van at a crossing
suddenly he starts rdiing backwards ...what the f...
hitting me and driving partly over the bike ????? and my leg blocked under the bike ....
idiot !
bike is at service center at the moment
fortunatly i have fust some bumps and scratches but i am fine
took out the ducati later that day for a spin yesterday to clear my head
idiot !
I'm refurbishing my heated grips due to the throttle side cable breaking for the second time .i found the original cable approx 4mm diameter twin core to be lacking ,ie cheap rubbish,and have replaced it with flexible microphone cable from maplin (£1.49 per metre) I found the 12v13w heating element poorly positioned . Just where your finger tips naturally rest there is a big gap ,see photo .
The element is not positioned centrally either
the most of my bikes i had upgraded with heating cartridges of COOLRIDE.
no breaking cables any longer!
regards
günni
regards
günni
