Now what?
Tinker
Now what?
Post by Tinker »
The next issue is sprag clutch seems to be on its way out. Twice today the starter has span up without turning over the motor. Does anyone know a generic part number for one? Thanks
ogr1
Re: Now what?
Post by ogr1 »
The exploded view in the workshop manual only shows & states a 'complete clutch'.
The code is M1614030. No 9 on the list.
Maybe a start in the right direction?
Carpe Diem Nil Desperandum
Tinker
Re: Now what?
Post by Tinker »
It is item 20 freewheel that I think is the issue
Painter
Re: Now what?
Post by Painter »
I have not had a chance to have a proper look but it could be using a similar cam shaped roller bearing as Ducati, that only grip one way and slips the other. When I have had problems with Ducatis I have always shortened the spring which works every time, just guessing here, if anyone knows better, I would be interested to know.
Tinker
Re: Now what?
Post by Tinker »
Ah cool i did see a video when someone did the same and shortened the spring. But I want to make sure it’s ok. I have ordered a flywheel puller. Has anyone got a sketch of the tool to hold the generator rotor flywheel thingy?
ogr1
Re: Now what?
Post by ogr1 »
According to the manual....
Tinker
Re: Now what?
Post by Tinker »
Thanks I have bought one of those it’s the other bit that goes inside the rotor to hold it while loosening or tightening the securing bolt
drego
Re: Now what?
Post by drego »
Hi Tinker,
You can find a picture of the original tool in the parts' list M00100006400. Here are two pictures of a homemade version.
Best regards
Robert
Tinker
Re: Now what?
Post by Tinker »
Great thank you Robert do you have the rough dimensions? I will get one made
drego
Re: Now what?
Post by drego »
Hi Tinker,
I am currently travelling and can only send them when I'll be back home on Thursday. The former importer März in Germany sells the original tool for about Euro70, but I don"t know whether they ship to the UK.
Robert
Tinker
Re: Now what?
Post by Tinker »
Thank you Robert there is no rush
drego
Re: Now what?
Post by drego »
Hi Tinker,
here are the dimensions:
Discs
- Outer diameter: 110mm
- Inner diameter: 50mm
- Thickness discs: 5mm
I ordered them on ebay for about 2€/piece
Height = axial distance discs (outer surface-to-outer surface): 42mm
Pins
- Diameter pins: 8.5mm
- Distance pins (center-to-center): 80mm
- Protrusion: 10mm
Best regards
Robert
Tinker
Re: Now what?
Post by Tinker »
Thanks Robert that is awesome I will get the welder out!
drego
Re: Now what?
Post by drego »
No problem. A piece of plastic tube (see photo) between tool and flywheel centers the tool and helps to overcome magnetic attraction
