Fans not working
Posted: 04 Jul 2014 15:26
by toggy
Hi all ,any ideas? . Both radiator fans not working . I've checked the fuse and 4 relays under the seat ,are there anymore on the bike? ,also noticed the reg plate light has blown and is not working ,even with a replacement bulb ,not sure if it's connected to the fans? Problem .The reg plate light is on the brake light fuse ,which are working fine.
Re: Fans not working
Posted: 12 Aug 2014 21:04
by toggy
Well I got the bike back from mota corsa ,seems there was a little corrosion in some block connectors under the tank ,all the connectors were pulled apart and cleaned and dosed with AFC50 ,and everything is working as it should ,nice easy fix . Just like the steering lock that wouldn't work ,that turned out to be the steering lock bolt adjusters near the yokes ,not adjusted properly .
